If the set did not have a 16:9 mode, your player would have to scale/downconvert a 16:9-encoded DVD in order to present it in its proper proportions on a 4:3 screen. In doing so, the player would have to toss out every third line of picture information in order to paint the letterboxing bars. With the 16:9 function, the JVC's entire scanning-line raster is collapsed into a 16:9 window, with the so-called "black bars" being nothing more than dead space. With your DVD player's setup menu adjusted to output a 16:9 signal, it can present the entire 480-line 16:9 picture at complete resolution.
Also, I think it's almost criminal how the sales staffs at most stores are not knowledgeable enough to be able to tell customers this. The 16:9 mode on some NTSC-only sets is the only reason left for buying non-HD units these days.
ok, i went in the menu and switched my ps2 to 16:9 screen. But when i put in a dvd that says "enhanced for 16:9 mode. it looks the same, and then when i press 16:9 mode on my tv remote, the picture gets even thinner to like almost 1/3 of the screen height.
It all depends on what the film was. Does the box of the dvd give an exact ratio? 16:9 will completely fill a widescreen tv, but may films have wider ratio's than that (2.35:1 for example) and so if you are watching one of those on a widescreen set you will still get black bars top and bottom and so if you watch one of these on a normal 4:3 tv the picture will have huge black bars top and bottom.
I have a 29" philips 4:3 TV. It has 4:3 expand but does not have 16:9 compress. Should I set my dvd player to 16:9 or 4:3, or can the set be adjusted to the squeeze mode? I know how to get into the service menu, but have no idea what's going on in there.
Jeremy, Gary: No, you do not have to change the DVD player's setup menu adjustments every time you switch between 16:9-encoded and 4:3-encoded DVDs. Select "16:9" and leave it alone after that.
Jack, although I haven't had the opportunity of trying this yet, wouldn't setting the player to 16:9 on a 4:3 TV cause distortion on non-anamorphic discs? I always assumed it would, or at the least it would put bars on the side of non-anamorphic material which would make the image really small on a 4:3 display.
It would if your TV didn't have a 16:9 mode. Many of the Sony WEGAs require that you manually activate the 16:9 mode; some do it automatically. The only menu you therefore need to consider on a day-to-day basis is the TV's (and then only if its 16:9 mode isn't automatic). But the DVD player need only be adjusted to 16:9 once; when playing a 4:3-encoded DVD it will pass a 4:3 image (be it a fullframe or letterboxed image that's recorded onto the disc).
Yep, I was confused on whether or not the player would pass a 4:3 image if the material being played was 4:3 non-anamorphic. Thanks for clearing that up.
