Kia
- Jun 16, 2001
Hello,
I have a Sony GDM-FW900 HDTV monitor display but it doesnt have component input, only a 15 pin VGA input. I'm wondering if any HD receivers have a VGA out connection. If not, would it be some how possible to use an IScan Pro or an adapter that can receive component input and output RGB VGA video with out degrading the signal at all? I've found a couple of adapters advertising component to VGA switching, but I'm worried if I decide to use one of the following devices, my video signal will loose detail. Here are the links to the two devices I speak of, and I know that the IScan Pro accepts component in and has VGA out.
http://www.copperbox.com/lite/popinf...neek=182944024
http://www.copperbox.com/lite/popinf...neek=272358431
I want to display the maximum resolution possible since my monitor is capable of reaching specs well beyond HDTV. Has anyone had experience using such adaptors? Any advice would be appreciated.
Kia
Kia
