15-pin RGB connection....
Discussion in 'Archived Threads 2001-2004' started by Mike Purfield, Oct 9, 2001.
  1. Mike Purfield
    Mike Purfield Auditioning
    Oct 8, 2001
    8
    Hi there everyone,
    I'm a greenhorn when it comes to HDTV, and I was wondering if anyone might be able to answer this question:
    If an HDTV with a 15-pin RGB connector can display the output from a computer's VGA card, does this mean that a computer monitor can display the output from a HD reciever's 15-pin RGB connector? I haven't seen much discussion on this, so my gut tells me no. That would make things too convenient. :) If anyone can clarify this for me, I would appreciate it! Thanks!
  2. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Mike, welcome to the HTF. I have a 15 pin (output) on my HDTV set top box, and I can plug this into my PC's monitor (input).
    If the TV has a 15 pin input, then a HDTV set top box can be plugged into it.
    If this came out wrong, ask again, but yes. Both the PC monitor and an HDTV TV would accept the 15 pin cable from a set top box.
    Glenn
  3. Mike Purfield
    Oct 8, 2001
    8
    Glenn, that's just the response I wanted to hear. Thanks! You've made my day! You see, being the poor college student that I am, I can't exactly afford a megabuck HDTV set. But I figured "Hey, my computer's monitor is nice enough, and some HD components use a 15-pin D-sub connector... Maybe it'll work..." So, how does the HD picture look on a PC monitor (other than the obvious "It's small." response)?
  4. Bill Slack
    Bill Slack Supporting Actor
    Mar 16, 1999
    837
    You could also get an HD card for your computer... certain ones will even let you record!
  5. Glenn Overholt
    Mar 24, 1999
    4,203
    I said that I had it, not that I had ever tried it out! [​IMG] Sorry! I'm sure that the picture would be great! Now, if they only would come out with widescreen monitors!
    Glenn
