14ga for a 50ft run OK?
Discussion in 'Archived Threads 2001-2004' started by JohnMW, Oct 31, 2001.
  1. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
  2. Mark Nelson
    Mark Nelson Agent
    Oct 19, 1998
    35
    Can't tell how many strands per conductor there are in the 4 conductor 14 Ga. wire, and it doesn't show many of the other specs that might tell you how good it is, but 14 Ga. is plenty beefy enough to go 50 ft, especially for rear speaker applications. It's quite possible that the 4 conductor stuff is actually better sounding audio cable than the 12 Ga. that Home Depot has and it's going to be a lot easier to install. I think you found "The Right Stuff"
    MTN
  3. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    Thanks for the reply. I am going to be using Paradigm Studio 80's up front, CC center, and 40's in the rear. I want to bi-wire all of them.
    I hope that AR cable will do the job well.
  4. Shanthi
    Shanthi Stunt Coordinator
    Aug 6, 2001
    109
    I am running 16 for 50 feet and I don't find any difference.
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    John: I'm sorry to rain on your parade, but I cannot back you up on this one.
    Try this: disconnect your front 3 speakers. Pop in a favorite DVD, turn off the TV and sit down in the room with a book/newspaper.
    Try and time how often the rear speakers make sound. My guess is they will only make sound 20-30% of the time. And how often do critical/important-to-the-movie sounds come from the rears? (Hint: never). Could this explain why some people use 16 ga and claim it sounds fine - there is just not a lot of signal to allow people to notice the difference?
    Do you really want to spend $$$ x 3 for something that only makes sound 20-30% of the time? And only non-critical/effect sounds at that?
    (Dont forget you need to run a set of wires for a rear-center speaker as well. Thats why I said "x 3".)
    It's your money and you can spend it however you want. (And I'm NOT against over-building. I do this myself. [​IMG])
    But you are talking a 2X factor to wire up the least-used, least-important speakers in your system. (Thats 2x to bi-wire, plus 1x for the rear center times 50 feet.)
    I'm afraid it's going to be a LOT of money for a fractional/un-noticible improvement in sound.
    Good Luck.
  6. Wayne A. Pflughaupt
    Aug 5, 1999
    6,301
    86
    9,110
    Corpus Christi, TX
    Wayne
    John, I think Bob has some valid points.
    But addressing your original question: If you are bi-wiring your speakers, it seems like dual 14ga. wiring is the functional equivalent of single-wiring with 12ga.
    Wayne A. Pflughaupt
    My Equipment List
    [Edited last by Wayne A. Pflughaupt on November 01, 2001 at 11:12 PM]
  7. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Brett Andrew DiMichele
    I run Radio Shack CL2 In-Wall 16Ga to my rears AND I DO get
    sound out of them 100% of the time (when in All Ch Stereo)
    and it sounds terrific on 16Ga. My cable runs are roughly
    40 or so feet.
    [​IMG]
    Brett DiMichele
    My Home Theater Site!
    [email protected]
  8. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    Thanks so much for the positive replies guys. [​IMG]
  9. JohnMW
    JohnMW Second Unit
    Dec 1, 2000
    280
    If I go with the Studio 100's up front, should I consider 12ga home depot wire w/ bannanas or use the dual 14ga AR wire that I will be using for the rear speakers?
    [Edited last by John M Welch on November 04, 2001 at 10:56 PM]
  10. Brett DiMichele
    Sep 30, 2001
    3,181
  11. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    If you're running in-wall you'll need to choose a cable that meets code in which case the AR should fit the bill. As to biwiring...well...at least its relatively inexpensive.
