130L seal box, shiva or tempest?
Discussion in 'Archived Threads 2001-2004' started by Andrew_Chan, Oct 14, 2001.
  1. Andrew_Chan
    Andrew_Chan Agent
    Aug 27, 2001
    39
    I've built a 130L seal box, I am a 50% music 50% HT person, would I shiva be better w/ that much space or a tempest?
  2. Brian Fellmeth
    Jul 30, 2000
    789
    With a very similar application, Dan Wiggins himself suggested I use a Tempest. Goes a couple Hz lower.
  3. Andrew_Chan
    Andrew_Chan Agent
    Aug 27, 2001
    39
    I was doing a search on sealed tempest, and people's comment aren't that good on the small seal box unless if there is Linkwitz Transform circuit. Would it be better off with a shiva?
    Also, is it possible to make a ported box, and then close the port whenever you need to lower Q for music?
  4. Andrew_Chan
    Andrew_Chan Agent
    Aug 27, 2001
    39
    How do I make a port that will produce F3 of 21Hz?
