joel jocson
Grip
- Jun 3, 2002
I am under the impression that there are 2 types of 12v triggers. Ones is similar to a cat5 connection while the other is a 3.5 mm mono plug.
Out of curiosity is there a way to get one to work with the other as you mix and match components??
