12V trigger on Pioneer
Discussion in 'Archived Threads 2001-2004' started by Adam Horak, Aug 29, 2002.
  1. Adam Horak
    Adam Horak Stunt Coordinator
    Jul 3, 2002
    123
    I recently lost a Tivo unit to a lightning strike so I decided to buy a nice power protector (got a Panamax Max 5100).
    I would like to turn the switched outlets (my amp and sub) on with a 12V trigger from my reciever (Pioneer D850S). The Pioneer has a 1/8" jack on the back called "control". The manual describes it as a control out for controlling other components. It does not seem to work in triggering the power unit. Does anyone know if this output will not work as a 12V trigger? If not, what would be the cheapest way I can trigger the power unit using a remote control?
  2. Lee Daza
    Lee Daza Agent
    Aug 10, 2002
    30
    I think, but am not sure, that the jack you are describing is for controlling other Pioneer products only, and is not a standard 12V trigger.
  3. JerryLang
    JerryLang Agent
    Mar 20, 2002
    26
    Is there a switched outlet on your receiver? If so you could get a 12v transformer [Radio Shack] to do the same thing.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,098
    33
    Katy, TX
    Wayne
    Adam,
    If this jack functions like older Pioneer equipment, is allows the master receiver remote to control via hard-wire other Pioneer components.
    Wayne A. Pflughaupt
  5. Adam Horak
    Jul 3, 2002
    123
