12 volt trigger, where can I get one?
Discussion in 'AV Receivers' started by EdNichols, Feb 2, 2005.
  1. EdNichols
    EdNichols Second Unit
    Feb 15, 2003
    372
    I have an amp for my mains that does not have the 12v trigger. I would like for it to come on when I turn on my receiver, is there something I can buy that will do this? If so, where can I get it?
  2. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    The Panamax 4310 and 4400 have voltage sensive 12v triggers so you can turn on the outlets to the amp via this trigger. Unfortunately, that means all outlets on the unit, so you wouldn't be able to plug in anything that you wanted to go into standby (with memory) on the same unit. The 5100 has a separate bank that can be turned on this way, but again, anything on that bank will also get turned off, and we are talking $200-$300 price range too.
    Take a look at them at www.powersystemsdirect.com
    Since your amp doesn't have a stand-by mode, it is probably OK to just leave it on all the time.
  3. EdNichols
    Feb 15, 2003
    372
    I thought about that but I wonder how much current I would be using when it is idle. I can't find any info. about the current it draws at idle.
  4. Dick Boneske
    Dick Boneske Stunt Coordinator
    Dec 31, 2004
    132
    This has got to be a common problem with many people using this forum. I, also have a separate subwoofer amp (a Hafler D-500) that draws too much current to plug it into the switched outlet on my Pioneer 1014. Someone must make a power strip or other device that will turn the outlets on with a trigger--preferably 120 volt for this application. The one device I've heard of for this costs more than $100.
    Anyone have more info??
    Thank you.
  5. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    My Monster Power Center HTS3500 Has 2 switched outlets, 2 switched and timed outlets, and 4 always on outlets. It has a 12v trigger, or it has a seperate power cord that you can plug into the outlet on the receiver to sense when the receiver is on.
    I have my main amp and sub amp on the timed outlets, and my BFD on the switched outlet. That way when the receiver poweres up, the BFD comes on. Then about 5 seconds later the amps come on. That avoids the loud thump in the sub if the BFD is turned on after the sub. Then they turn off in the opposite manner.
    It is nice because everything does not power on at once, which could cause a hugh power spike.
  6. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    For an inexpensive solution, I would suggest the Smart Strip (based on what I have read on forums, not my own use of it - I have triggers on my amps).
    You can get yourself a Smart Strip from here:
    http://www.bitsltd.net/SmartStrip/index.htm
    Be aware that if your idle current draw from your receiver is above the trigger point for the unit, then it may not work - you should probably look at the LCG3 for $33.00 which has better current sensing (according to their website)specifically for this reason.
    Brian - FYI I leave my BFD and Outlaw ICBM on 24/7 to avoid the thump. Generally anything in the receiver>sub path will thump unless you have delayed/timed power ons similar to what you are using.
  7. EdNichols
    Feb 15, 2003
    372
    Thanks, just ordered a Smart Strip and it looks like what I have been needing.
  8. Walter Scott
    Walter Scott Agent
    Nov 2, 2004
    36
    Go hhere: http://www.xantech.com/
    Under products look for "Remote Control Swithces." Check out the AC1 or AC2.
  9. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    I use a Russound ACT-1 to power almost everyhting from my receiver's switched outlet with a 12v power supply on it (same on/off trigger as a 12v trigger). Works great.
  10. syeo
    syeo Agent
    Nov 3, 2001
    27
    I turn on my QSC amp via X10/IR/Remote, H/K amp via 12v, and leave BFD on 24/7. Works for me.
  11. Bill NHT
    Bill NHT Auditioning
    Dec 7, 2004
    5
    I'm using a Smartstrip LGC4 to power two seperate amps with my Yamaha RXV-995, and works without a problem. I have a 1014 on the way and will be using that receiver instead. There is a little knob on the powerstrip I have that allows the sensivity to be adjusted, but I'm not sure if the lower models have the knob.
  12. Blaine_M
    Blaine_M Second Unit
    Mar 11, 2004
    400
    John, on the Panamax web site it says that some of them are switched, I do not believe they are all switched. If I read it right it looks as though you can maybe adjust that on some of the models. The 4310 looks like a nice unit for the price. Anyway, here is where I read that....in fact it looks like 3 are always on, and 4 are switched on the 4310.
    http://www.panamax.com/products.cfm?...il&id=208&ly=h[/url]
  13. Claude M
    Claude M Stunt Coordinator
    Jan 18, 2001
    239
    I'm using the Russound Act 1 as well. Works great and it's not $$.
