12 volt trigger on Parasound
Discussion in 'Archived Threads 2001-2004' started by Kevin Deacon, Feb 25, 2002.
  1. Kevin Deacon
    Kevin Deacon Second Unit
    Dec 18, 2001
    319
    I recently upgraded to separates and am running a Marantz AV-550 pre/pro and a Parasound 2003A amplifier. The parasound has the ability to auto turn on when a 12 volt signal is received. I have read through the Marantz owners manual and it states that the Marantz can trigger other Marantz amplifiers through a wire (RC-5??? I think) connection.
    Does anybody know if the Marantz's signal is 12 volts? The owners manual does not state this specification. If so, can I use the correct pin input for the back of the Marantz and the split the wire for input into the Parasound amp? The Parasound has a + and ground input I believe?
    Any help would be appreciated.
  2. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Kevin,
    I couldn't answer you question if the signal is 12v but one thing you may consider is going to Radio Shack and getting a 6-12v power adapter and plugging it into the back of your pre/pro if it has the outlet. This way every time you power on the Marantz the amp will be triggered. You can try e-mailing Marantz but I've had no luck getting a reply from them.
    Kevin
  3. Sankar
    Sankar Second Unit
    Aug 1, 1999
    315
    One way to be sure is to get a voltmeter and measure the output voltage. That way you also get to identify the polarity.
  4. Kevin Deacon
    Dec 18, 2001
    319
    Thanks for the advice Kevin and Sankar. I sent Marantz an email just to see if they respond. I'll see if any friends have a voltmeter to test the output. If all else fails I can use Kevin's solution. Thanks
