12 v amp trigger connection
Discussion in 'Archived Threads 2001-2004' started by Jim Noble, Aug 20, 2002.
  1. Jim Noble
    Jim Noble Extra
    Apr 14, 2002
    23
    Can you connect the Rotel RSP 1066 to the RMB 1095 amp's 12 v trigger input with a standard audio cable of the type supplied with the 1066?
  2. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    it should work fine since its a very low current signal. Please be aware though that the amp triggers only seem to work if the second zone is turned off.
