12 gauge as opposed to 16 gauge
Discussion in 'Beginners, General Questions' started by mattCY, Feb 10, 2006.
  1. mattCY
    mattCY Auditioning
    Feb 9, 2006
    Hi,
    Hoping someone can answer this question for me. I have a Pioneer VSX-D914-K, it's my beginner receiver, and I have 12 gauge Radio Shack speaker wire hooked up to my speakers and am wondering if it would be better to use 16 gauge Monster Speaker Cable or should I keep my 12 gauge.
    Sorry, this is a nub question.
    Mattcy
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,187
    51
    9,110
    Katy, TX
    Wayne
    Keep the 12 ga. It’s larger than 16 ga. Typically larger gauge is better than smaller.
    Oh yes, weldome to the Forum!
    Wayne A. Pflughaupt
  3. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,451
    338
    9,110
    Cees Alons
    What Wayne says. The 12ga is the better choice. There will be (a little bit) less loss.
    Cees
  4. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    At one time, Monster made the 12 ga MegaCable speaker wire sold by Radio Shack.
    I do recommend the dual-banana plugs 279-306 if your reciever and speaker terminal have the right spacing. These things make it easy to do a neat wire job. (12 ga is sometimes hard to wire up because it is so thick).
    Dont get brain-washed over speaker wires. While wires do have a small influence on a music system, HT systems are much less sensitive to wires.
