12 gage low-voltage wire for speakers?
Discussion in 'Speakers' started by BillyP, Jan 7, 2004.
  1. BillyP
    BillyP Auditioning
    Jan 6, 2004
    3
    I'm looking for speaker wire to setup my new HT. I will probable need between 200 and 250 feet of wire. I found some 12 gage wire for 37 cents/foot, which is much less than I have seen any other regular 12 gage (speaker) wire for. This wire says it's for low voltage outside lighting, but to me 12 gage wire is 12 gage wire. Will this wire work OK for speaker wire, it will have to be partly in wall also, if that matters. I could save quit a bit of money this way to go toward better speakers.
    Thanks, Billy
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Sure. Like you said, 12 zip cord is pretty much the same. You can get this in big 100ft spools from parts express, etc etc. I don't recall what my local home depot was selling it for, but i don't think they had big spools, and it was a tad bit more per foot i think.
    However codes usually do require that in-wall wire be rated for in-wall use. This pertains to speaker wire as well. I am not too familiar with the problems/liabilities with not running in-wall wire for in-wall use.
  3. BillyP
    BillyP Auditioning
    Jan 6, 2004
    3
    It was Home Depot I found this 500' roll of 12 gage wire for $158. The guy said it was 37 cents/ft, but I guess if you buy the whole spool it's only about 32 cents/ft. At least that's what I figured it out to be. I think I'll get the whole spool, then I'll have wire left to wire lights in my yard [​IMG]
    Thanks again,
    Billy
  4. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    Billy,
    I thought I paid much less for my in-wall 12-gauge wires from Home Depot. The wire I got was made by Carol. I seem to recall paying around .25 a linear foot for mine.
  5. BillyP
    BillyP Auditioning
    Jan 6, 2004
    3
    The guy helping me said they had no 12 gage "speaker" wire, but I did find this 12 gage lighting wire. Maybe this particular Home Depot was just out or something. I may try another location. It's still much less than Radio Shack's 99 cents/ft 12 gage wire.
  6. Scott Sabin
    Scott Sabin Stunt Coordinator
    Jun 20, 2002
    54
    Boy, that seems expensive for the 12 ga landscape wire. I recall paying less than 20 cents/ft for mine (in 100 ft quantity) from Home Depot.
    You might also want to consider using 12 ga Romex for the in-wall portion (maybe even 10 ga for that long run). Then you are convered for in-wall use.
