10Base-T and 100Base-Tx in english?
Discussion in 'Computers' started by Eric_L, Aug 7, 2003.
  1. Eric_L
    Eric_L Screenwriter
    Nov 2, 2002
    1,994
    My router used to show I was connected to the host computer by 100Base-Tx. After I upgraded the Mobo and used the onboard LAN it shows I have 10-Base-T.
    If I knew what that meant I'd be either pissed or impressed. I've noticed no change in performance....
    Any ideas?
  2. MikeAlletto
    MikeAlletto Cinematographer
    Mar 11, 2000
    2,369
    Basically 10 megabit per second as opposed to 100. You want 100 if your hardware supports it.
  3. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Basically the 10x is 10 megabytes per second vs 100 megabytes on the other connection. Obviously 100 is 10 times as fast as 10 meg connection all things being equal.
  4. Eric_L
    Eric_L Screenwriter
    Nov 2, 2002
    1,994
    It is a wireless router, I suspect that the DLS connection and wireless technology are nowhere near 100base-Tx speeds yet. I just checked and I had it reversed. My router is presently connected via 100Base-Tx.
    Thanks for your info.
  5. Andrew Pratt
    Dec 8, 1998
    3,806
    Right your DSL connection is likely in the 1 to 3 megabytes area so you won't notice any difference for downloading where you'd notice is large file transferes across your LAN (between local PC's)
  6. MikeAlletto
    Mar 11, 2000
    2,369
  7. Curt Irwin
    Curt Irwin Auditioning
    May 7, 2003
    2
    1. Network communications are measured in megabits (Mb). Internal storage megaBytes (MB), a Byte = 8 bits. Notice the caps.
    2. 10BaseT = 10Mb, 100BaseTX = 100Mb, ten times faster. Inall reality it peaks at about 75% of that depending on the use of hubs or switches. Switches provide for a dedicated connection between machines and are much faster.
    3. Wireless has three standards, A, B, and G. A runs at about 11 Mb, B runs at 11/22 Mb but has better range and security, G has a 54 Mb speed and even better security. They all work like 2.4 GHz phone systems, and it is recommended to get either B or G - probably G.
    4. DSL ranges from 256 Kb (Kilo (thousand) bits) to 3 Mb (Mega (million) bits). Depends on what you pay, but yes it is far behind.
  8. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
  9. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
  10. MikeAlletto
    Mar 11, 2000
    2,369
    But A is in 5Ghz band where G is in 2.4Ghz like B (reason I mention it is 2.4 interfers with microwave ovens and 2.4Ghz phones, as well as some other things).
  11. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,357
    293
    Cees Alons
