1080p Plasmas. They Exist?
Discussion in 'Displays' started by Mike JM, Mar 25, 2006.
  1. Mike JM
    Mike JM Stunt Coordinator
    Jan 18, 1999
    77
    I just did a quick search on new 1080p plasmas. I looked up the Panasonic TH-50PX50 and the native resolution is 1365 x 768. That's not 1080p. ?
    So I'm asking in a new thread what 1080p plasmas are currently out there that are between 42" inches and 60" or so.
    Nothing comes up at Crutchfield, Best Buy, New Egg. ....nothing 1080p.
    I am in the market for a new tv. I plan on getting something 1080p in a few months. no doubt, by november.
    Any other info would be a great help.
    Thanks.
  2. willyTass
    willyTass Supporting Actor
    Sep 9, 2005
    502
    95
    610
    They had one at display at CES 2006 last month but its not out yet.
    I cant remember if it was Panny or pioneer maybe both.
    They haven't been released yet
  3. Robert Hoffman
    Robert Hoffman Stunt Coordinator
    Mar 9, 2001
    184
    I think Panny and Pioneer are both coming out with 1080P Plasma displays, but plan on waiting a while longer (another 3-6 months).
    As an alternative, you could get the NEC now which will take a 1080P signal over component or DVI and at least display it (at 768P). I don't think the present offerings from Panny or Pioneer will do that.
    Remember, especially if you're contemplating a 50", the difference between 1080i and 1080P will be negligible unless you're planning to sit closer than 5-6 feet away from the TV.
  4. Mike JM
    Jan 18, 1999
    77
    You don't think the current
    Panasonic TH-50PX60U (came out a couple weeks ago, now at www.circuitcity.com) can take a 1080p and display it at... 720p or 768p ?
    I can wait 6 months. I just need to fill my brain with some info.
    There's a Westinghouse 42" for only a couple grand right now that does 1080p. But it's an LCD.
