1080i dvd players
Discussion in 'Playback Devices' started by ishak, Mar 30, 2004.
  1. ishak
    ishak Auditioning
    Jan 26, 2004
    14
    does a dvd have to be mastered in high definition to upscale to 1080i.
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Nope... thats the point of UPSCALING... it SCALES UP a 480i image to HD resolutions.
  3. Bernie_A
    Bernie_A Stunt Coordinator
    Feb 3, 2004
    112
    Hope you don't mind me piggy backing onto your thread, but what's the problem with mastering the disk at 1080i to begin with? Will we ever see that so it's a true HD picture?
  4. ishak
    ishak Auditioning
    Jan 26, 2004
    14
    so can any dvd be upscaled to 1080i
  5. Jay Blair
    Jay Blair Second Unit
    Nov 3, 2001
    333
    Yes, any DVD, any VHS tape, any laserdisc, any video can be scaled to 1080i, or 1080p for that matter.
    However, scaling a DVD to 1080i does not turn it into HD resolution. Upscaling will usually make the 480i DVD look better, but it still doesn't look like HD.
  6. Bernie_A
    Feb 3, 2004
    112
    So for now, it's virtual HD....
  7. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Yes its virtual HD, nowhere near real HD quality. I prefer a quality 480p DVD player since the source on the current DVD format is limited to 720x480 resolution. You have to wait a few years before a new HD-DVD format will be available with any significant titles and cost.
  8. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    What the 1080i DVD player should do is:
    (2) De-interlace the 480i from its MPEG decoder into 480p. (All DVD players have (1) MPEG decode the data on the disk into 480i.)
    (3) Scale up the 480p into 540p.
    (4) Fit the 540p into a 1080i signal format wise (a no-brainer) while the content remains 480 lines of resolution vertically and 720 max pixels across horizontally.
    Some HDTV sets display only in 1080i. They will perform steps (3) and (4) for you for progressive DVD player feeds and will perform (2), (3), and (4) for interlaced DVD player feeds.
    So the main advantage of a 1080i DVD player is if it can do steps (3) and (4) better than your TV. In addition you need to be concerned about whether the player does (2) better than your TV.
    Video hints:
  9. Don_Berg
    May 30, 2003
    931
    I would say a 1080i upconverter shouldn't de-interlace at all, just scale each 720x240 field up to 1920x540, don't add de-interlacing artifacts.
  10. Gil Jawetz
    Gil Jawetz Stunt Coordinator
    Sep 14, 1999
    95
    Hmmm... I've been thinking about getting the new Zenith 1080i player for my Zenith C32V37 but I don't know if it'll have a significant impact. Obviously there's no way to know until it comes out.
  11. Allan Jayne
    Nov 1, 1998
    2,404
    >>> I would say a 1080i upconverter shouldn't de-interlace at all, just scale each 720x240 field up to 1920x540, don't add de-interlacing artifacts...
    Not as good. This softens the picture.
    If you go directly from 720x240 up to 1920x540 you might get something like this in the finished 1080i. Two examples are shown, on the left is a straight repetition of scan lines with even and odd 1080i fields shown slightly staggered, and on the far right uses blending, also with even and odd fields shown slightly staggered in the diagram. Note particularly that the odd 1080i field could be made only of odd original lines and the even 1080i field could be made of only even original lines. Since simply doubling the scan lines gets to 480 but we need to ultimately get to 540, a few more scan lines need to be repeated every now and then and they are shown around where original scan line 4 is found.
    1 .................. 1
    . 2 ...................... 2
    1 .................. 1&3
    . 2 ...................... 2&4
    3 .................. 3
    . 4 ...................... 4
    3 .................. 3&5
    . 4 ...................... 4&6
    5 .................. 5
    . 6 ...................... 6
    5 .................. 5&7
    . 6 ...................... 6&8
    7 .................. 7
    . 8 ...................... 8
    7 .................. 7&9
    . 8 ...................... 8&10
    Whereas by de=interlacing first we could get something like this after scaling to 1080i, again with no blending on the left and with blending on the far right. Again, to get from 480 to 540 a few extra scan lines need to be duplicated after the de-interlacing is complete and this is shown around where original scan line 4 is found and again around original scan line 9.
    . 1 ...................... 1&2
    2 .................. 2
    . 2 ...................... 2&3
    . 3 ...................... 3&4
    4 .................. 4
    4 .................. 4&5
    . 5 ...................... 5
    5 .................. 5&6
    6 .................. 6&7
    . 7 ...................... 7
    7 .................. 7&8
    8 .................. 8&9
    . 9 ...................... 9
    9 .................. 9
    . 9 ...................... 9&10
    Here the scan lines are never out of order.
