1080i and 720p
Discussion in 'Displays' started by Don Keegan, Apr 8, 2005.
  1. Don Keegan
    Don Keegan Agent
    Aug 16, 2003
    39
    does any hd programing come in 720p? my cable box has a selection for it but i see colored wavy line across screen when selected
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    This might have more to do with the TV not being able to handle 720p ...
    FOX and ABC are 720p ... (among others) but the cable box normally converts it to 1080 based on your set up of the box.
    Regards
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Right.. Most allow you to set it at one or the other, some also have a pass through or native which means it goes to the display as it was sent from the broadcaster. This is output and somewhat exclusive to the actual source. Your box takes either one automatically and outputs it per the selection.
    If it is set to 1080i, then any and all resolutions it recieves are output at 1080i.
  4. Don Keegan
    Don Keegan Agent
    Aug 16, 2003
    39
    Thanks for the quick relies!
