1014 and Predator
Discussion in 'AV Receivers' started by JoeyR, Mar 3, 2005.
  1. JoeyR
    JoeyR Second Unit
    Jan 1, 2003
    422
    Joey
    Tried test running the part about Jesse's gun and my receiver is showing dolbydigital even though I have the DTS version.
    Also with 4 E30s and a EC35 center channel, I set the E30s from large to small after autoMcacc, is this correct?
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Did you go into the Audio Menu and set it to DTS?
    DVDs do not default to DTS even if they are the DTS version (to prevent damage to equipment if somebody did not have a DTS capable reciever)... you gotta manually set it to DTS yourself in the menu
  3. JoeyR
    JoeyR Second Unit
    Jan 1, 2003
    422
    Joey
    Which menu nick? I know on Saving Private Ryan that option comes up, on Predator it didnt when you start the DVD
  4. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    audio menu
  5. JoeyR
    JoeyR Second Unit
    Jan 1, 2003
    422
    Joey
    Will recheck for that thanks ryan
  6. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Do other discs with DTS do the same thing? If so, check your DVD PLAYER'S menu and make sure DTS is on and set to "bitstream".
  7. SteveAZ
    SteveAZ Auditioning
    Dec 17, 2004
    14
    DTS is usually under Audio Setup or Language Selection.
  8. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Yeah saving private ryan had a screen before the movie for you to choose, most dont have that so you gota go into the Audio Selection/Audio Setup/Language Selection menu to change it
  9. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    For a few years, there were alternate editions of movies that were DTS versions. SPR is one of these movies - there were both DD and DTS versions. These are the only movies that will have the DTS or Dolby Stereo selection screen on start up, and I am pretty certain there are no new titles that are being released like (except maybe Superbit) this likely due to confusion over having two versions.
    Pretty much all DVDs will default to Dolby Stereo/surround or DD.
