Richard Harvey
- Jun 22, 1999
Ok, me and a friend are debating the best way to take his $1K and get the best set of front mains and center channel. He is planning to use an SVS 20-39 for the sub. He is driving it with a Denon 2802 receiver. The goal is to get the best sound & quality, paired with this sub, within his price range. He is open to towers or bookshelves, but would want to know the reasons why you would recommend one over the other (he's not convinced that quality bookshelves might be the way to go).
If you have specific brands & models, that would be great!
Edit: Forgot to add -- his room is approx. 18' x 14', and opens into a side dining room. It is carpeted/tiled (now), but the carpet may soon be replaced with wood. Ceilings are 12'. We also have local access to demo Boston, Klipsch, B&W, Paradigm, Mirage, Polk, Infinity, and Definitive if there are specific models you would recommend (other brands considered, too).
Rich
Rich
