~$1000 budget, need help
Discussion in 'Speakers' started by JayG, Dec 7, 2003.
  1. JayG
    JayG Auditioning
    Dec 7, 2003
    7
    I have approximately $1000 and I'm looking for a complete 5.1 system. I'm new to the Home Theater scene, so I don't have a whole lot to go on.
    I was looking into buying the Sony DAV-FC9 HT in a box ($700), but since I never make any major purchases wihout extensive research, I started looking around, and from what I hear, that wouldn't be a very good move.
    A little background, music is more important to me than movie sound, although that's important as well. I'm a classical music buff, so that will be a large part of the music I'll be listening to, if that makes any difference. I'm also into classic rock and some new rock/alternative.
    I heard the Sony system I mentioned earlier at Best Buy and it impressed me, but like I said, I don't have much to compare it to. Also, at the store all the speakers and the sub were bunched together so I couldn't really get a feel for how well it does for surround.
    Ideally, I want to be able to listen to both SACD and DVD Audio. I was under the impression that any DVD player could play DVD Audio, but I have seen some conflicting information, so I would appreciate it if someone could fill me in on that.
    Keep in mind I need 2 main speakers, a center, 2 surrounds, a sub, an amp/receiver, and a CD/DVD player unit, and my budget is around $1000. I hope it's not out of the question to get a decent system for that much.
    One of the things I liked about the Sony system is its compactness, considering much of its time will be spent in a dorm room, but size isn't a deciding factor as long as it's not huge.
    I hope I've provided enough info for you guys to go on. Any help would be greatly appreciated.
    Thanks.
  2. JohnPop
    JohnPop Stunt Coordinator
    Nov 26, 2003
    54
  3. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    I would go with
    JBL S26 $150 free shipping x2 = $300
    JBL S Center $130 free shiping
    Pioneer VSX-D812K $230 + shipping
    Sony DVP-NC685V 5-Disc DVD/CD/SACD Changer $204 + shipping
    Sony SA-WX700 250 Watt Active Subwoofer $198 + shipping
    A little over $1000 but the JBL studio series are clearing out, and are very good speakers, I think you will end up with a very nice setup. But if you cant pass the $1000 range you could change the speakers to,
    JBL NSP-1II 5-Piece Home Cinema Speaker System $199 free shipping
    Or you could also get a single dvd player, like
    Pioneer DV-563A DVD/SACD/DVD-Audio Player $154 + shipping
    Good luck with your setup,
    Pablo
  4. CurtisSC
    CurtisSC Screenwriter
    Jan 28, 2003
    1,412
  5. JohnPop
    Nov 26, 2003
    54
    I had no idea on the receiver in that range, so I just said something that was popular [​IMG] So therefore dont go just off of what I said, but rather search for the onkyo unit and see what others suggest in the threads.
    The Ventriloquist certainly looks nice and would be great for HT, but I am not so sure on two-channel performance, but I am sure nothing performs all that well in such a small config.
    I would also take a look into getting two bookshelve speakers and a center channel for $550. You would get better music performance, but would be lacking the Sub and the surrounds which may not be a big deal to you. The sound should be more clear from these more expensive units, so youll have to decide whats right for you. In this category you may want to look at the ELT Bookshelve and center channel by www.av123.com This also opens the door up to many other mfgs. So ...
    BTW I am getting the full ELT system with an upgraded sub. they have great support over there at www.av123.com and If you go for the 3 speakers versus 5 and the sub, then be sure to ask some questions at their forum
  6. JayG
    JayG Auditioning
    Dec 7, 2003
    7
    Thanks for the replies. It appears as though I have a lot to look at. The more input the better, so keep it coming. [​IMG] Thanks again.
  7. Ian_J
    Ian_J Stunt Coordinator
    Oct 15, 2003
    101
    If you're a music buff, I recommend buying a quality 2 channel system first.
    Axiom M60ti $800.00 (shipping is free)
    Used 2 channel receiver around 125 wpc $200.00
    Sony SACD player $200.00
    $1,200.00 and you'll have 3D sound (but not surround sound).
  8. Alex Prosak
    Alex Prosak Supporting Actor
    Dec 9, 2001
    773
    AV123 also has a ELT/Denon AVR-1804 package for $1250, add a Pioneer DV-563A and you're good to go.
