Greg Warner
- Dec 20, 1998
Hello,
I plan on purchasing B&W dm303's all the way arround for my home theater as
I have been reading nothing but good reviews (plus they fit my budget on an
almost to good to be true level). These speakers are rated at 100 watts.
Would 100 watts suffice for a room with the dimensions of 19 x 11 and a
ceiling height of 7'? I will also be using a psb subsonic II to handle the
base and set the speakers to small. Is there any formula, so to
speak, for room size to power?
Greg
Greg
