10" Sub recommendation
Discussion in 'Archived Threads 2001-2004' started by BrandonD, Jul 24, 2002.
  1. BrandonD
    BrandonD Auditioning
    Jul 15, 2002
    3
    I've been looking at a couple different subs, namely the Dayton titanic mkII 10", and this NHT 10" sub. They are going to be stuffed into a 3 way tower enclosure, where the sub enclosure can be anywhere from 1cf^3 to 2cf^3, the midrange and tweeter are the Audax HM170Z2 and the AW025S3, which is a design by Vance Dickason. The subs actually going to be ran off of the LFE channel most of the time for theater use. My price range is anywhere up to ~$150/each. Can anyone make me another recommendation or comments on the 2 subs i've referenced?
    --Brandon
  2. Joe Meissner
    Joe Meissner Stunt Coordinator
    Jan 31, 2002
    204
    BluePrint Drivers
    http://www.missiondigital.net/product.asp?productid=2
    1001 T/S Parameters
    Fs 21.1 Hz
    Re 3.20 Ohms
    Qms 4.55
    Qes 0.31
    Qts 0.29
    Cms 596 uM/N
    Mms
    Sd 308.50cmsq
    Vas 80.50 liters
    SPL dB
    BL TM
    X-max 33mm p-p
    Power 200 watts RMS
    $81
    these look mighty nice for the price.
  3. Ryan Schnacke
    Ryan Schnacke Supporting Actor
    Feb 5, 2001
    876
    Did you notice that those NHT's are 12 ohm? If you're buying two then you could put 'em in parallel and run off a single sub amp for a 6 ohm load.
    Those blueprints look really good on paper. Same displacement as the Titanic but lower Fs (and higher Vas). This seems like the obvious choice.
  4. BrandonD
    Jul 15, 2002
    3
    Hmm, that driver looks great especially for $81/each, but I don't see any way I can contact them. The order page doesn't exist, and theres no email or phone number. [​IMG] I guess i'll try to get a reply from the feedback page or something.
  5. AndersP
    AndersP Stunt Coordinator
    May 17, 2002
    53
