Say I could get a used, well-regarded current-model multichannel amplifier at a price where the price/power ratio is $1/watt. Would that be considered a pretty good deal?
Would you buy a car buying in horsepower per dollar?
Example: A $15000 car has 100 horsepower, $150 per horse (think compact, Corolla, Focus or the like...I'm using convenient numbers).
Now consider a $70000 car with 200HP. Now you're paying $350 per horse. But the car is a Benz, or BMW or something like that.
Which would you buy? The cheaper one? Or the more expensive one (per horse). What if we entered a $52500 car into the equation with 150HP. That's still $350/horse. The car could be turbocharged though...who knows.
This logic is useless. I'm sure if it's a good well-regarded amp that it's been discussed thoroughly on these forums already. The Search feature is your friend. And knock it off with this dollars per watt business. If you buy something based on that you're an idiot.
Anyways, I could go and get some crapola thing from Best Buy (cheapest they have) which puts out 100x5. I'm sure if we compared that to a Parasound HCA-855A which is 85x5, I'm sure the Parasound would win hands down.
But then again...if what the original poster is talking about is well respected, well then it's probably not a bad item. Why not check eBay auctions to make sure you're getting a good deal?
Wow, looking back over this thread, you guys are a tough crowd! Just so my credibility isn't totally shot, I will address why I brought up this issue.
During the past few weeks, I have been looking for a low-end five-channel amplifier. Brands I researched were Adcom, Outlaw, Parasound, and Rotel. Meaning: I read every possible publication on the Internet and read nearly every thread that the HTF search function returned. Imagine my disdain when I am simply told to use the search feature. I did not look into Acurus, Anthem, ATI, Classe, B&K, or Sherbourn.
Now being a college student, I can't just buy any amp - it has to be a good amp at the lowest possible price. When you look at the brands that I mentioned, the overall consensus is that they are all good and that I will be happy with any one of those. Well that's the problem. They are all so similar that there is simply no way to subjectively choose. One way to break it down is to try to get the maximum amount of power for the lowest possible price.
Power means absolutely nothing. Doubling it results in a +3dB gain. That's it. And when you consider that you'll rarely ever need that much power continuously, those amps are pretty much all on par with each other. If you're looking for loud, then go to Best Buy and buy the thing that cranks the loudest. If your ears are bleeding, there's no way you'll be able to tell the difference.
Since you haven't bought anything, keep one eye looking out here for good deals (but as always, caveat emptor). But you *ABSOLUTELY* have to go and visit dealers and *HEAR* these amps. The relationship between you and your amp will go far beyond a one night stand, so you should really put the effort into travelling to various dealers, hearing these things, seeing what you like, what you don't like. And get prices. Absolute best prices. Negotiate, lowball...do what you have to to get the best price you can new on these things. The differential to me with my 1075 was $250CND. That got me a 5 year warranty (you roll the dice when you buy used as to whether or not the warranty will still apply), a reputation with my dealer, a brand new amp, the amp in silver like I wanted (all the used ones at the time were black), and I didn't have to hold my breath until it got here hoping that it would arrive just as promised. And considering the amp will last a while (if you choose properly), $250 means nothing. If you're as price conscious as you appear to be, why are you risking buying blind?
