1 Pair Speakers, 2 Receivers: Is This Possible?
Discussion in 'Archived Threads 2001-2004' started by Dave Simpson, Mar 23, 2002.
  1. Dave Simpson
    Dave Simpson Second Unit
    Sep 18, 1999
    445
    Hey guys, hope you can help me out regarding some connection matters for a friend. This is what he proposes: he's currently enjoying two-channel music with an older Yamaha receiver (two-channel only; no DPL or 5.1) and plans to continue doing so, but he also plans to purchase a Kenwood VR-507 for DD and DTS decoding (HT use only). Speakers are B&W 600i bookshelf model, balance of 5.1 set-up to follow. Is it possible to connect both receivers at once to these speakers for simplicity of operation? I.E.) Yammie receiver to bottom set of speaker inputs (or top), Kenwood receiver to top set of inputs (or bottom), jumper bars remaining in place, powering on one receiver while the other is definately off. CD/DVD (same unit) connection will be analogue out to Yamaha, optical out to Kenwood. Is this feasible? Thanks a lot for any help. Cheers.
    DS.
  2. Adam Krogul
    Adam Krogul Stunt Coordinator
    Feb 25, 2002
    66
    im not sure.. never thought about doing something like that. the best way to check is to use a ohm meter on the amplifer and check the resistance between the "+" and "-" teminals of one channel when it is off... if it read an open circut...then i dont see a problem but if you have some measurable resistence there than you might have a problem... make sure you test both amps and both of their outputs when they are off.
    good luck,
    l8rz,
  3. Joe Tilley
    Joe Tilley Supporting Actor
    Jan 1, 2002
    686
    Dave, I would not reccoumend doing this it can damage the recevers (trust me Ive done it myself before).
    If you wonted to hook them both up to the same speakers I would look for some type of selector switch that would cut the reciever off that is not in use at the time so that you are not sending power into the other recivers amp section.
  4. Miles_W
    Miles_W Second Unit
    Aug 16, 2000
    436
    I agree with Joe, I don't recommend doing this... for the reasons stated
  5. StevenK
    StevenK Second Unit
    Jul 16, 2000
    266
    I'm sure they make some kind of switch for this purpose don't they?
  6. PaulKH
    PaulKH Second Unit
    Oct 3, 2001
    413
    Dave Simpson - I had a similar situation and solved it with a fabulous 'box' made by Jamo. It allows two sets of amp/receiver connections in, and supports up to 4 sets of speakers out, and it will make sure the amp/receiver sees one 8ohm impedence regardless of how many speaker sets.
    I realize this is overkill for what you need, and it was for me too, but it's a high quality box (all gold plated banana capable connectors).
    Recommended.
  7. Dave Simpson
    Sep 18, 1999
    445
    Great suggestion, Paul! Any idea on the cost and availability of such a box? Cheers!
    DS.
