1 in. MDF in NJ
Discussion in 'Archived Threads 2001-2004' started by FredV, Feb 21, 2003.
  1. FredV
    FredV Agent
    Dec 27, 2002
    27
    Anyone know where I can get MDF in NJ thicker than 3/4 in?
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Where in NJ? I didn't find anything over 3/4" in stock anywhere (if I recall, been a while) but my local place could order me up to 1&1/8. Heavy stuff, Fred.
  3. FredV
    FredV Agent
    Dec 27, 2002
    27
    Anywhere in NJ. I figure you can't get this any ole place.
    BTW, if you just double up on 3/4 in. MDF, what's the best way?; to glue them?; glue and screw?
  4. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    i just glued and clamed almost every where i could
  5. Jack Gilvey
    Mar 13, 1999
    4,948
    Fred,
    You can certainly laminate sheets to any thickness you like, most people just use wood glue and weight/clamp evenly.
    I think a better way is to build a box from, say, 3/4" material then, when it's done/dry, "build" another box around it. Just laminate another sheet onto each side overhanging by about 1/8" and use a flush-cut router bit to get the edges perfect. This is easier and safer since you're not trying to horse large, heavy pieces into a saw. I think Brian Bunge told me about this method, but I can't find the procedure detailed anywhere.
  6. Brian Fellmeth
    Jul 30, 2000
    789
    As a variation of what Jack just said, you can make thicker panels and avoid the difficulty of cutting the thick panels. Cut the 3/4 to exact size, then cut the add on panel slightly larger. Combine them with yellow wood glue and use weights or clamps making sure that the larger rough cut panel overhangs a little on all 4 sides. Then use flush trim bit to cut the overhang and you've got a thick panel of exact size.
  7. FredV
    FredV Agent
    Dec 27, 2002
    27
    Do you think glue used for hardwood floors would be useful?
    I'm thinking perhaps by using a spreader, one can even get a benefit of"deadening" the wood.
  8. Brian Fellmeth
    Jul 30, 2000
    789
    so long as you can get a thin uniform layer should be fine. But plane yellow wood glue works great for these laminations.
  9. Michael Lynch
    Michael Lynch Auditioning
    Dec 6, 2001
    10
    I can't remember which one but I believe one Home Depot had 1" MDF. I was shocked to see 1" but maybe it was the Linden store and this was 3-4 months ago (sorry for the non help here). I've been to Linden(Rt 1), Sayreville(Rt 9), Kenilworth(Rt 22), and others. There is also a woodshop in Plainfield that sells MDF (New Jersey Hardwoods). I'm not sure if they have 1" but a phone call would find out. I bought full sheets of 3/4 and 1/2 there and they could probably make some of the cuts for you.
    Hope this helps.
  10. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    when i bult my box i used lap joints the inner pannel was 3/4smaller than the oter. so i bult the inner box then added the seccond layer to it.
  11. Tim Morton
    Tim Morton Stunt Coordinator
    May 5, 2000
    212
    Have you tried going to one of the non-big box stores and asking them about the chance of ordering it for you? I can do that here in South Podunk Vermont, its really worth the effort so as not to deal with gluing . I built my subwoofer out of 1" Mdf and it is masssive...used almost the entire sheet including 4 internal braces and double front and back.
