1.85:1 & 16:9
Discussion in 'Displays' started by Rex.G, Mar 17, 2004.
  1. Rex.G
    Rex.G Stunt Coordinator
    Feb 8, 2004
    120
    Should you see small black bars when watching a 1.85:1 film on a calibrated 16:9 screen??
  2. Jason Charlton
    Jason Charlton Ambassador
    May 16, 2002
    3,557
    415
    4,110
    Baltimore, MD
    Jason Charlton
    In most cases, you won't see any black bars due to overscan, which is typically anywhere from 2-5%, but sometimes higher. If you were to manually adjust overscan on your display and reduce it to 0 (which most people would recommend against) THEN you would see the black bars.
    -Jason
  3. joey mr
    joey mr Stunt Coordinator
    Jun 26, 2003
    127
    if you are talking about a rear pj yes you should see black bars because the wide screen format on those sets have is 1:78.1 hdtv is a little bigger hight wise then the 1:85 screen .cheers
  4. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    If your overscan is at about 2% or so ... then you should be able to see the black bars on some 1.85:1 films.
    On other 1.85 films, they just open up the top and bottom and reformat the film to 1.78 ...
    Regards
