Arthur S
- Jul 2, 1999
I have a Technics SH-AC500D DD decoder hooked up to an older Nakamichi reciever that cost $1100.
The problem seems to be that in DD mode, the bass from the subwoofer is about 25db less than it should be. The bass is there with the decoder in DTS and ProLogic.
It could cost well over $100 to get the decoder fixed.
I'm also using another older receiver that cost $500 to get make shift 6.1.
I would hate to have to box up $1,600 worth of receivers.
One thought is to get the Denon 3802 for $699 if it is still available.
Any tests I could do or any suggestions/advice will be appreciated.
Artie
Artie
Artie
Artie
