007: EON on HDTV
Discussion in 'Gaming' started by ethan_l, Feb 19, 2004.
  1. ethan_l
    ethan_l Stunt Coordinator
    Oct 25, 2002
    72
    I read from some other board that
    this game is not compeletely done in 480P,
    in fact on the driving levels and some of the FMV's are
    so it switches between 480i and 480P
    if this is the case then that really blows,
    anyways if any of u videophiles get the game plz confirm
    thanks
  2. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    It's 480p in both, as long as you do NOT have 1080i selected in your dashboard, allegedly.
  3. Dave F
    Dave F Cinematographer
    May 15, 1999
    2,885
    2
    Are you sure they weren't talking about Agent Under Fire?
    -Dave
  4. Dean Martin
    Dean Martin Stunt Coordinator
    Jan 21, 2004
    185
    Agent under fire is 480i throughout the game, could be the one.
  5. ethan_l
    Oct 25, 2002
    72
    guys I'm pretty sure they were talking about the latest game
    EON
    yeah and I just read about the 1080i solution too,
    but it seems like the game does not support widescreen either
  6. Dean Martin
    Jan 21, 2004
    185
    Unfortunately a lot of games don't support widescreen. It looks good stretched though.
  7. James Lee
    James Lee Stunt Coordinator
    Feb 6, 2001
    196
    Turning off 1080i DOES fix the problem in 007: EON. I've got my Xbox hooked up to Component2 of a Samsung DLP display, which does not support 480i, so when I tried EON, I got no video.
    When I turned off 1080i in the Xbox dashboard, now I get a signal and the game works.
    As for widescreen support, the menu screens are not in widescreen, but is when you actually play the game.
  8. Dave F
    May 15, 1999
    2,885
    2
    I have every resolution turned on in the dashboard, and the only the menus show up as interlaced. I just played an on foot level, a driving level & watched a CG FMV, and each was 480p. And as James mentioned, the game is widescreen.
    -Dave
