Jump to content
CONSOLIDATED LOTR:FOTR Extended Ed. Problem Thread; Please Post ALL Problem Reports Here!
  • Please log in to reply
189 replies to this topic
#1 of 190 OFFLINE   JeffreyMercado
JeffreyMercado
  • 326 posts
Posted November 12 2002 - 05:47 AM
I put on the DTS 6.1 track on the new extended version of LOTR and found the bass was lacking. I took it out checked the calibration, everything was normal. I then checked my samson amp, I have a SVS sub, again everything was fine. I popped in AOTC and thought wow with the opening ship scene. Switched to DD on the LOTR disk and the bass was there right away. A huge difference, could this be a bass problem like the one on the initial release of Jurassic Park? If you are having the same problem please let me know.
#2 of 190 OFFLINE   Ken_McAlinden
Ken_McAlinden
    Producer
  • 6,150 posts
  • Real Name:Kenneth McAlinden
  • LocationLivonia, MI USA
Posted November 12 2002 - 06:11 AM
Does your amp have a LFE gain setting for DD and DTS? Typically DD should be at zero and DTS at +10 (that's usually the maximum allowable setting for both). Also, there could be a volume offset (not just bass though) depending on the dialnorm setting for the DD track. I will listen to some of both tracks this evening. Regards,
Ken McAlinden
Livonia, MI USA
#3 of 190 OFFLINE   JeffreyMercado
JeffreyMercado
  • 326 posts
Posted November 12 2002 - 06:23 AM
All I had to listen to was the beginning during the war with Sauron. The troops marching, fighting, and then his arrival, lots of bass on the DD track. When he blows up there's a wind cloud that really goes low as it spreads out. On the DTS track it was very humble sounding. If I put in my DTS version of Jurassic Park I it scares everyone just with the opening credits.
#4 of 190 OFFLINE   Josh Lowe
Josh Lowe
  • 1,063 posts
Posted November 12 2002 - 06:36 AM
do you have a harman/kardon receiver?
#5 of 190 OFFLINE   Paul W
Paul W
  • 468 posts
Posted November 12 2002 - 07:21 AM
I have too much bass during the last alliance scene. And all in the wrong places. When the archers start firing, there are some huge booms and then when Sauron walks up, nothing. I wonder if therer is a sync problem with the DTS track.
"Hairs are your aerials. They pick up signals from the cosmos, and transmit them directly into the brain. This is the reason bald-headed men are uptight." —Danny, Withnail and I
#6 of 190 OFFLINE   Joe Woj
Joe Woj
  • 47 posts
Posted November 12 2002 - 10:46 AM
Just want to know if anybody else encountered these problems are not... There are two spots on the DTS track where there is a slight hiccup and freeze up...it only happens for a second, shorter than a layer change, but it's there. The first one happens right after the Fellowship of the Ring logo is displayed on the screen, with Bilbo is writing in his book, during the new introduction to the Shire. The second time is right before Aragorn begins to talk to Boromir while they are resting in Lorien. It's right before he says..."take some rest...these borders are well protected..." These only happen on the DTS track...I tested all the other sound tracks, including the commentaries, and it only happens on the DTS track. Has anyone else noticed this or do you think it's a problem with my discs? Edit - I have the Toshiba 4800 and the Sony HT-DDW740 receiver.
"In the deep of night under hard clear stars they set off. They faded swiftly and softly into the darkness. Over all the leagues of waste before the gates of Mordor there was a black of silence."
#7 of 190 OFFLINE   Trent_N
Trent_N
  • 46 posts
Posted November 12 2002 - 11:08 AM
My X-Box isn't able to recognize the LOTR:Extended DVD I picked up today (my computer DVD player doesn't have any problem with it). Is anyone else experiencing a similar problem? Any recommendation on how to fix the problem? Thanks.
#8 of 190 OFFLINE   Trent_N
Trent_N
  • 46 posts
Posted November 12 2002 - 11:09 AM
Sorry about the double post.
#9 of 190 OFFLINE   Michael Reuben
Michael Reuben
    Studio Mogul
  • 21,769 posts
Posted November 12 2002 - 11:11 AM
Please report all problems LOTR:FOTR Extended Edition in this thread. Also, take the time to read other posts; you may find that someone else already has addressed your particular problem. M.
COMPLETE list of my disc reviews.       HTF Rules / 200920102011 Film Lists
#10 of 190 OFFLINE   DaveGTP
DaveGTP
  • 2,096 posts
Posted November 12 2002 - 11:16 AM
I got a second-and-a-half or so skip about halfway through each of the first 2 discs. (I think the first was approx when Gandalf got to Orthanc?) I am hazarding a guess that it was a layer change?? I'm using my PS2 as my DVD player...
Matheson- "There are probably some who'll say that by doing this, we are interfering with their culture."
Gideon - "Probably. Screw them."
-Crusade, Visitors from Down the Street
#11 of 190 OFFLINE   Eric C D
Eric C D
  • 285 posts
Posted November 12 2002 - 11:32 AM
I got the same momentary freeze as Dave GTP - as Gandalf arrives at Orthanc. I only noticed it because the birds weren't moving. Was it the layer change? Haven't watched the second disk yet. Where's that hiccup? Eric
#12 of 190 OFFLINE   BrettisMckinney
BrettisMckinney
  • 281 posts
Posted November 12 2002 - 11:40 AM
I heard somewhere that active subs with their own crossover and levels will show huge problems with disc if they are not calibrated right.
#13 of 190 OFFLINE   Adam_WM
Adam_WM
  • 1,629 posts
Posted November 12 2002 - 11:59 AM
watched it today on DTS. Sony receiver, Panasonic Prog Scan player. AWESOME. No problems. Bass sounded tremendous.
#14 of 190 OFFLINE   Joe Woj
Joe Woj
  • 47 posts
Posted November 12 2002 - 01:21 PM
[quote] I got the same momentary freeze as Dave GTP - as Gandalf arrives at Orthanc. I only noticed it because the birds weren't moving. Was it the layer change?
[quote]
Ya that part IS the layer change. There is another simmiliar change on disc 2 as well. But my problems are different...which is why am worried it's my discs.
#15 of 190 OFFLINE   DaveGTP
DaveGTP
  • 2,096 posts
Posted November 12 2002 - 01:44 PM
Aha! That's what I thought it was. You home theater-serious guys are educating me Posted Image Is this an issue with the game-machines turned DVD players? Anyone know if the Sony DVD-player update might clear it up? Or am I going to be forced to go buy a real DVD player? Posted Image I don't think the 7 cents in my bank account will cover it...but even such a little thing kind of bugs me..
#16 of 190 OFFLINE   Steve_Tk
Steve_Tk
  • 2,833 posts
Posted November 12 2002 - 02:02 PM
No problems here. Panasonic DVD and HK reciever.
#17 of 190 OFFLINE   Aaron Garman
Aaron Garman
  • 382 posts
Posted November 12 2002 - 02:47 PM
Hello all. Watched the EE today in DTS and it sounded terrific! I did note that the bass after Sauron explodes was not as deep as the Dolby track, however the DTS just felt clearer, more natural, and simulated what I remember hearing in the theatre over 7 times. Now onto The Appendices... AJ Garman
"It's been my lifelong ambition to be a movie usher, and I have failed, as far as I am concerned" - Bob Dylan
#18 of 190 OFFLINE   JeffreyMercado
JeffreyMercado
  • 326 posts
Posted November 12 2002 - 02:48 PM
I have an Outlaw 950 prepro and it was my friends extended edition. I get my gift pack from Amazon tomorrow so I will have to test again. All of my equipment has been calibrated with an Avia and Video Essentials disk. I really hope my disk will be alright.
#19 of 190 OFFLINE   NateLindsey
NateLindsey
    Extra
  • 19 posts
Posted November 12 2002 - 03:16 PM
One problem I had was towards the end of DVD 1. When Aragorn stands up to offer Frodo his support in the Fellowship, the dvd just froze. I backed it up a little bit and hit play and it finished out the DVD fine. I have a Pioneer DV-525. I'll have to watch it again to see if it happens again and it wasn't just a fluke.
#20 of 190 OFFLINE   Benjamin_L
Benjamin_L
  • 84 posts
Posted November 12 2002 - 03:36 PM
Trent, The 1st disc in the extended edition worked fine in my X-box. Maybe yours is damaged? I haven't had time to test the 2nd or the supplementals, did you try them out as well? Peace!
XBLIVE GAMERTAG: the light
"Life is such a changing art."
-Dar Williams
