-Not Logged In-
Jump to content
Need help quick!! Banana Plug hookup question!
  • Please log in to reply
2 replies to this topic
#1 of 3 OFFLINE   Dan Da Silva
Dan Da Silva
  • 74 posts
Posted July 19 2001 - 10:07 AM
alright guys I feel really stupid asking this question but I need to know the answer before I go to home depot tonight. I have a Sony DB-940 reciever and the speaker cables that I'm using now are plugged into my reciever with bare wires stuck in the binding post. Now my question is I want to get some new 12 gauge cables and banana plugs tonight, but how exactly to I hook up the banana plugs to my recievers binding post??? do I stick it in the same spot that my bare wire is now and then just screw it down. Or do I stick the banana plugs into the holes that are on the front of the binding post?? ------------------
#2 of 3 OFFLINE   Brian Schucher
Brian Schucher
  • 704 posts
Posted July 19 2001 - 10:09 AM
Right into the holes on the front. Tighten the nuts down then stick the plug in the hole.. Posted Image
#3 of 3 OFFLINE   Mark Dubbelboer
Mark Dubbelboer
  • 1,011 posts
Posted July 19 2001 - 10:51 AM
Once you have the banana plugs in your hands it will all make sense...believe me I don't think there's any other way to hook them up ------------------
