Jump to content
A power question about my Denon AVR-3300
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   Dave Miller
Dave Miller
  • 854 posts
Posted July 13 2001 - 05:53 PM
I just bought a Monster Power HTS Power Center and I'm wondering where I plug in my receiver. Is the Denon AVR-3300 considered a "high current" component that I would need to plug it into the switched plugs (Amp 1 & 2), or should I just plug it in where it says receiver, which is considered "low current?" Peace, DM ------------------ "We all end up dead, the question is how and why."
#2 of 5 OFFLINE   Andrew Pratt
Andrew Pratt
    Producer
  • 3,813 posts
Posted July 13 2001 - 07:16 PM
if you've got the space to plug the denon into a high current plug why wouldn't you? I'm not sure you'd hear a difference though either way. ------------------ http://www.attcanada.ca/~itisi
#3 of 5 OFFLINE   Dave Miller
Dave Miller
  • 854 posts
Posted July 13 2001 - 09:12 PM
Andrew, I want to put the plug in the right place. Technically the 3300 is a receiver, correct? The owner's manual says the Receiver plug is for "low current" components and the Amp 1 & Amp 2 plugs are for "high current" components. That's why I want to know if the 3300 is high current or low current. Make sense? DM ------------------ "We all end up dead, the question is how and why."
#4 of 5 OFFLINE   Rick P.
Rick P.
  • 64 posts
Posted July 14 2001 - 01:31 PM
Dave, if Monster Cable doesn't define 'high' or 'low' current in their literature then it probably doesn't matter from an electrical standpoint. However I believe the high current switched receptacles have a time delay, usefull for amplifiers that don't have their own delay relays built-in (probably not too many of those out there anymore, either). Since the 3300 has a built-in output delay you don't need this feature, so use a low current receptacle. Rick ------------------
#5 of 5 OFFLINE   Dave Miller
Dave Miller
  • 854 posts
Posted July 14 2001 - 03:45 PM
Thank you Rick. That's helpful. DM ------------------ "We all end up dead, the question is how and why."
