Jump to content
How hot is too hot ?
  • Please log in to reply
4 replies to this topic
#1 of 5 OFFLINE   JohnnyDee
JohnnyDee
  • 6 posts
Posted February 06 2002 - 06:41 PM
Hi all. Just recently joined the forum after lurking for several weeks. What a wealth of information! I was finally getting into HT and searching this site has answered many questions while setting up my system. Question: How hot is normal for a reciever? I am sure they all have overheat protection, but the cooler they run, the better, correct? After a good workout my RXV-1200 is too hot too place your hand on top. Should I take steps too keep it cooler or is this ok ? I don't remember my older stereo recievers getting this hot. ( Maybe I just never paid attention, I am constantly playing with my new toy)
#2 of 5 OFFLINE   Evelio Figueroa
Evelio Figueroa
  • 484 posts
Posted February 06 2002 - 07:36 PM
[quote]
[quote]
Hmmm....You're not blocking the vents, correct? Make sure nothing is on top of it. (Like a DVD player or any other component.) If its in a rack, you may want to place some cooling fans to keep it from overheating. You need to protect the delicate parts inside.
My Pioneer VSX-49TX sits in a rack. I have a few cooling fans on it to keep it from overheating. Head to my site if you like to see what I did.
#3 of 5 OFFLINE   David John
David John
  • 54 posts
Posted February 06 2002 - 07:53 PM
I have the RX-v1200 also and mine only gets very warm after a couple hours of use. I live in an apt. so I can't really crank it up, but it's never gotten very hot.. only very warm.
I have about 5 inches clearance between it and the next higher shelf.
Maybe you need more room above it, and some better airflow to cool it.
If it doesn't go into protection from the heat, I wouldn't worry too much, just do what you can to keep it cool.
It will help extend it's life.
My Adcom amp which powers my subs and rear surrounds gets much hotter, but i can still touch it after a couple hours of use. It does have thermal protection too, but it has never triggered.
I was concerned with the heat, so i drilled a grid of holes in the top of my ent. center to help vent the heat.
So far so good. Posted Image
#4 of 5 OFFLINE   PatrickM
PatrickM
  • 1,140 posts
Posted February 06 2002 - 10:12 PM
Definitely give it a lot of room for ventilation if it gets that hot. My old Sherwood 8090 receiver used to get pretty warm after a particularly aggressive soundtrack but my Denon 5800 barely gets warm even when cranked. Patrick
#5 of 5 OFFLINE   Lewis_W
Lewis_W
  • 32 posts
Posted February 07 2002 - 02:34 AM
I wouldn't worry about it. Have you ever touched some of the big Parasound amps after playing them at near reference level through a set of M&K's? They get really hot, with plenty of space around them. Also, the Lexicon MC-1 runs pretty hot, but it's no real cause for concern. Lewis.
