Folks: I have a projector that was installed when the house was built in 2007. I posted some pictures in another thread. People here recommended I stick with a projector, so i am trying to figure out how to get HDMI to the projector. After disconnecting everything, I found that could pull (hard pull) the component video cable through. I chose one of the three component video cables and pulled it about 1/2 way with a nylon cord taped to it. It got jammed and could not go through. Just the extra diameter of the cord + single layer of electric tape kept it from coming through. Something is restrictive inside the walls.
So, I think trying to fish an HDMI cable through is not going to happen. Someone suggested CAT6, but I am totally confused. Do I buy a roll of it without ends? What ends do I install if I can get it through? Do I need two runs of CAT6? I am hoping that if I run just one wire, then maybe it will fit through whatever is hanging it up now.
Advice desperately needed. Thanks
