I've been reading up on several low cost pro amps and trying to decide A: should I go the pro-amp route? And B: If I do go the pro-amp route, who should I go with? I've read up on Alesis, Behringer and Crown, specifically, and have to say, it seems Crown is the best choice, though I really know nothing. A few drawbacks I'm noticing are fan noise and THD. Pro amps seem to all be at .5% THD which is fairly high when you consider that most home theater receivers are in the .08-.05% range. I've read that anything under 1%, however, shouldn't be audible.
Given those concerns, has anyone had a good experience with pro amps for your home theater design? I am going full Atmos (because why the hell not?) . Planning to use the Onkyo PRSC5530 with the Polk in-wall RT-series speakers. My equipment rack will be on the other side of a sound-deadened wall so fan noise shouldn't really be an issue. IR repeaters should make this really easy. I'm on a bit of a budget (as in I don't have one and have to snag pieces of the setup every pay period), so I'm really attracted to the price of pro amps. But if they are going to produce a lot of noise through the speakers, I guess I'll stretch the non-existent budget and go the Emotiva route or somesuch.
Thoughts?
Thoughts?
