Hello,
I'm not a home theater expert, but I saw that you all have solved some fairly intricate problems, so I figured I'd ask as well.
I have three questions:
1. My subwoofer is spotty. It plays certain notes and when it does play, it doesn't sound right (almost too loud). It is a klipsch 6.1 system w Denon receiver. I've had the same results with another receiver and I've also tried another speaker cable. I plugged the sub into my friends system and it played flawlessly, so I don't think it is blown. Any thoughts?
2. I have my cable box in the coat closet and the TV/sound bar above the fireplace. A universal remote hub (logitech harmony home control) cannot send IR signal through walls. Why can't the harmony remote send IR signals? Can I get a second hub to set up in the room, and have both communicate with the remote? How do I get everything to communicate?
3. I bought a 100' HDMI cable with a built in signal amplifier from Frys and fished it through the wall. The TV now has flashes of static. It has a dial on the amplifier to tweak the signal but I can't seem to tweak the dial just right to remove all static flashes. Before I fished it, I tested it out on a different box and it worked flawlessly. Why did it change after being fished? Could it be the different box?
Ryan
Ryan
