Hello.
I want to put the subwoofers of my home cinema in a hidden place, as you can see in the picture the idea is build an structure into the wall.
Option A: apart from the inner space, i will put a surface of 4cm of height in contact with the floor to avoid hitting the subwoofer with the feet.
Option B: is in direct contact with the floor.
The entire structure is made of wood and drywall.
Is this a workable idea?
Thanks!
Thanks!
