bradypunch
Grip
- Jul 13, 2015
- Brady
I recently had my house burn down (March 17th), and now I am going to rebuild my home theater room. Unfortunately I was underinsured on personal property so I am on a budget and will be on these forums looking for advice; hopefully I'll find some good advice from people since I have been out of the loop for some time. Here is a little info about the room size, usage, etc.
The room is in the basement and is 19' x 11'9". It will be a dedicated room for home theater/music, and will have theater type seating, sound panels, and bass traps(eventually). It will be used for movies 70% of the time and music the other 30%. I have a Klipsch Synergy 12" that was given to me the other day, and I want another sub to run with it. I also have a Rotel RMB 1075 amplifier and Yamaha RX-V1600 receiver(Which I plan on replacing).
For a second sub I was looking at the Definitive Supercube 6000 and the Klipsch R-115SW or Klipsch R-112SW. I do not have my mind set on these particular models but they are ones that seemed to be decent to me. The other option I was looking at was BIC Acoustech PL-200 for the money saving which would allow me more cash to spend on other components.
For tower speakers I was looking at the Bic PL-89 II or PL-980's. Polk Audio and Klipsch were also in my sight as well.
Any advice is welcome; I have been out of the audio market pool for a long timer and I am needing to do this on a budget. Thank you for the advice.
