Hey guys, I am pretty new to all of this, so ask me if I didn't provide enough information about problem.
My setup
I have got Samsung Smart TV (not sure what model), Harman/Kardon home theatre (most probably 65BQ) and Satellite box from local provider.
I am using theatre as main input/output device. Sattelite TV box is connected to it with HDMI for video and Optical cable for audio (optical cable was needed, because I couldn't get any audio with HDMI only and Sattelite box says, I need optical cable for 5.1 sound)
My TV is connected to theatre with HDMI (ARC slot, because I am using YouTube and other apps)
What is happening?
Every so often I lose the audio. I can only see video (TV).
Somebody just wake up, turn on TV, sattelite box, theatre and they can only see video.
The only fix I found is to turn sattelite box and theatre off (no electricity) and turn it back on together.
When everything works as it should, HT says HDMI INPUT 1 PCM. I noticed the 'PCM' part is missing, when the problem occurs (no audio).
I would like to fix this problem so I won't have to restart everything everytime. It's not really practical and I guess it shouldn't work like that... If you have any idea what should I try, tell me! Thank you for help.
My setup
What is happening?
