HELP with Xbox One and PS4 Connection to Projector (1 Viewer)
kathy13xia
Kathy Xia
David_Jr said:
Niles makes nice IR extenders that work well. The sensor goes in your HT room and then the wire extends behind it to your rack area.
Can't agree more.
Birdog
Brian
I would go with black speaker covers and wall outlets. The white is distracting. It's an easy fix. You can get flat black spray paint and in 30 min. you are done. Good luck.
blitz
