Mark Vaykhansky
- Apr 9, 2015
Hey guys I need your help.
I’ve recently moved to a new flat and I’m currently planning my living room.
When we’ve been working on the design of the house we didn’t take into account the stereo system and hence there’s a little design problem right now.
This is the plan for the living room as viewed from my sitting position on the couch:
http://imagizer.imageshack.us/a/img673/4503/UW2CmM.png
this is how it looks now:
http://imagizer.imageshack.us/a/img538/6686/Tto0wt.jpg
This is the how the living room is supposed to look from the TV’s stand point looking at the couch:
http://imagizer.imageshack.us/a/img673/333/FA0o1U.png
This is how it really looks:
http://imagizer.imageshack.us/a/img661/2408/c9Ywz0.jpg
My living room blend with the guest table, the entrance door and the kitchen like so:
http://imagizer.imageshack.us/a/img673/205/9LTyBz.jpg
http://imagizer.imageshack.us/a/img905/9151/xWOGqv.jpg
I hope you understand a little bit how the entire place looks
As can see in the design of the TV wall the piece of furniture underneath the TV is supposed to be from the left to the right border wall with no gaps.
This places the following questions:
A few details that might help:
Thanks a lot!!
- Where do I put my front speakers? Should I make a gap for them like so:http://www.hometheater.co.il/files/(3701)_img_2973.jpg or maybe lean them of the funiture like so:http://www.hometheater.co.il/files/35388~img617.jpg
- My major question is whether I need a subwoofer or not. In case I do, where do I put it? I guess the it should sit as low as possible so I don’t see how I can fit it in the front.
- the viewing distance is 3.5m
- the ceiling hight is 2.5m
- there are mounts up the wall for the back speakers
- I will replace all the front and the TV. First I want to plan the sound system.
Thanks a lot!!
