ok please can any tell me if the woofer in the Htp 210 does it say pioneer inside on the woofer itself or does it just say woofer and then have pioneer on the front of the box
I'm confused too, but trying to take a shot - the subwoofer is the big one with a different kind of connector (it doesn't use standard speaker wire). Can't you just compare it to a picture on-line?
