I have installed a Russound ALT-126R volume control and need help determining the impedance match setting.
The setup is this:
Yamaha R-s700(set to 8ohms)>Niles Audio SS-6 speaker selector.
From the speaker selector are 3 pairs of Infinity P162 (rated 8ohms)
1 pair of B&W 686 (rated 4ohms)
The Volume control is between the speaker selector and the B&Ws.
How do I determine the impedance setting on the volume controls?
The instruction manual includes a chart, but I cannot tell if the speaker selector changes things. Do I treat it as if the B&Ws are the only pair? Or do I include all of the 8ohm pairs?
Any help is appreciated. I can post the chart if it helps. thanks.
The setup is this:
