This is the exact dual light switch plate that controls my cellar and basement.
The first switch, on the left, controls the divided half that contains the water heater, furnace, etc.
It's the second switch, on the right that controls the lighting in the larger part of the basement where my home theater will reside.
It's a simple on and off switch. It controls two large drop ceiling lights.
I want to turn that switch into a dimmer that can be remote controlled by an app and is compatible with the Logitech Harmony remote controls.
Nothing hugely expensive. Must be simple to install, as I know nothing about doing this kind of work (other than turning off the power before I do it).
Any suggestions?
