allendehl
Grip
- Jun 6, 2012
- Allende Hernandez
Hi folks,
I just bought a bose accousticmass speaker system to use with my Denon AVT-1712 reveiver. I had my room cabled for a different speaker set so all the cables for the speakers come from behind the receiver. I also ran the subwoofer inside the drywall and placed a female RCA plug in the wall to run just a small extension to the unit.
I see now that the bose system comes with an all-in-one cable that runs to the subwoofer and goes to the speakers from there. My questions are:
Can i safely use my current connections from the receiver direct to the cubes?
If so, is there such a converter cable from rca to the one the subwoofer takes that only passes thru the SB signal?
Thanks a lot in advance!
