aka_gk
- Feb 2, 2015
- Kirill
Hi,
I need help putting together old config:
front — Dali Blue 5005,
center — Dail C1000,
rear — Dali R1000,
subwoofer will be later.
Receiver — NAD T742 (Rear ports for reference http://audiozavar.com/wp-content/uploads/2013/08/p1110005.jpg )
TV is new — Sony 49X8505 (rear - https://dl.dropboxusercontent.com/u/7460606/Screen_shot%202015-02-02%20at%2020.28.36.png )
Questions:
1. Since avr is old, there no HDMI's. Will it work if I connect all sources (htpc, ip-tv etc.) via HDMI to TV, then send sound as follows Digital Audio out -> NAD T742 Digital in -> Speakers ?
2. Rears are wall-mounted, but in current apartment I don't have walls to hang them onto (atleast not on both sides). Will I have any luck finding stands for them? I didn't so far, bottom twitter placement makes it even harder.
Thanks in advance.
rear — Dali R1000,
Questions:
Thanks in advance.
