Need some help piecing my home theater sound together. (1 Viewer)
asi_a
Hi All, I'm putting together my 7.2 home theater sound system and need some advice. My room is 17'x24' and is on a raised foundation, I sound proofed the room with insulation as well as sound board. So far I have the following i'm going to use.
Denon AVR-X3100W
Klipsch RC62 Center Speaker(placed in my built in cabinet)
Klipsch RB61 Front speakers(bookshelf placed in my built in cabinet)
HSU VTF-2 MK4 Subwoofer(front, likely to be placed in my built in cabinet)
KG-5150 with a boxed 12" subwoofer(placed in the rear corner of the room)
What I need now are just surround and rear speakers. Would definitely like to stick with Klipsch and in wall for these, preferably round. Can anyone provide specific model numbers of what may work best?
Thanks in advance for any advice.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
It’s generally best to use speakers from the same product line all the way around. Klipsch has two pairs of so-called surround speakers in the same Reference line that your center and front L/R are part of. Alternately, the RB 61s could also be used as surrounds.
By the way, insulation does very little for sound proofing. Good soundproofing requires room-in-a-room construction or at the very least staggered stud, along with double or triple-layered sheetrock, among other things.
Wayne A. Pflughaupt
acinstallation715
