Jump to content
Looking for a garage door opener - recommendations?
24 replies to this topic
#1 of 25 OFFLINE   Philip Hamm
Philip Hamm
    Lead Actor
  • 6,885 posts
Posted January 04 2002 - 01:41 PM
I have a small single bay garage so I don't need mega power. Looking to spend as little as possible but don't want junk. Posted Image Recommendations?
Philip Hamm
Moderator Emeritus
#2 of 25 OFFLINE   Scott L
Scott L
    Producer
  • 4,466 posts
Posted January 04 2002 - 01:49 PM
Just chiming in cause I need one too.. Are there models that are marketed for low noise? I'm a night person in a suburban neighborhood who tends to take out their trash at 11:00pm or later. Posted Image
#3 of 25 OFFLINE   Alf S
Alf S
  • 1,437 posts
  • Real Name:Alfie
Posted January 04 2002 - 04:13 PM
I think your best bet would be going with a Sears Craftsman. Seem to last a lifetime, and not too pricey.
Note: I would consider getting one with the new security code scrambling technology and an electronic lock feature.
Our neighbors got broken into because someone used one of those universal garage remotes and drove around our neighborhood trying out different codes (that many older openers and some new ones have) until they got a door to open. They got several tools out of his garage, but didn't break into the main house.
Alfer
WOOSAH!.
#4 of 25 OFFLINE   Steve Tannehill
Steve Tannehill
    Producer
  • 5,527 posts
  • Real Name:Steve Tannehill
  • LocationDFW
Posted January 05 2002 - 02:43 AM
I went with the screw-based (as opposed to chain-based) Genie from Home Depot. It was a little pricey, though.
- Steve
#5 of 25 OFFLINE   Philip Hamm
Philip Hamm
    Lead Actor
  • 6,885 posts
Posted January 05 2002 - 02:55 AM
I am soooo not sold on the screw type openers!! I remember their commercials where some moron was talking about "If you've ever seen a chain on a bicycle and it goes 'jam jam jam' well the screw is smooth". In fact I HAVE seen a chain on a bicycle and they're perfectly smooth unless you're changing gears. Same with my motorcycle chain. And the chains are incredibly strong. However, I have seen more than one screw crossthread and/or splinter due to heavy use. No thanks! Keep that sucker lubed! I'm going to my local Sears Hardware RIGHT NOW to take a look, I think they have a Craftsman low end model (All I need for my small door) on sale.
Philip Hamm
Moderator Emeritus
#6 of 25 OFFLINE   Philip_G
Philip_G
    Producer
  • 5,035 posts
Posted January 05 2002 - 06:05 AM
I bought a genie screwdrive last summer for my apartment, 1/3rd horse or something (the smallest they make) and for my single car door it's great, pleanty of power, even when the door is frozen to the ground Posted Image
screw drive is the way to go, they are MUCH quieter than a chain drive, and they're easier to put together, and there's a lot less to adjust. (I have installed both)
I think I paid about 80 for mine on sale, plus another 30 for a keypad so I can get into my garage without carrying an opener with me (nice to be able to get my bike out with full gear on and not fumble around for the damn opener)
#7 of 25 OFFLINE   Steve Tannehill
Steve Tannehill
    Producer
  • 5,527 posts
  • LocationDFW
Posted January 05 2002 - 09:27 AM
Well, the screw-type openers have worked for years for my friends and myself. Suit yourself.
- Steve
#8 of 25 Guest_Eric Kahn_*
Guest_Eric Kahn_*
Posted January 05 2002 - 09:34 AM
Sears garage door openers are made by chamberlain right now
I have a genie chain glide model but I admit that I bought the cheapest one availible and noise what not an issue because my garage is not attached to my house
the quietest openers are some of the new tape drive models
I think consumer reports just did a test of openers
check out the library
#9 of 25 OFFLINE   Steve_Ch
Steve_Ch
  • 982 posts
Posted January 05 2002 - 11:02 AM
>>Our neighbors got broken into because someone used one of those universal garage remotes and drove around our neighborhood trying out different codes (that many older openers and some new ones have) until they got a door to open. They got several tools out of his garage, but didn't break into the main house. <<
Happens a lot in the older days when garage doors were installed with a default code. People would just drive down new homes development and set their garage door opener to default code. A LOT of garage doors will just open as people move in their houses but never bother to change the garage door opener code.
#10 of 25 OFFLINE   Philip_G
Philip_G
    Producer
  • 5,035 posts
Posted January 05 2002 - 01:48 PM
I can't speak for other brands, but the one I installed each opener comes with it's own code, and the opener "learns" the code for each remote and stores it by pressing a learn button on the opener then the button on the remote, rather than changing some dip switches on both.
#11 of 25 OFFLINE   MikeSerrano
MikeSerrano
  • 350 posts
Posted January 05 2002 - 06:19 PM
I have had both chain and screw-drive openers, and if I were to ever get a new opener, I'd go for the screw-drive. They're easier to install and maintain and (as pointed out above) quieter. And for those concerned about heavy use, I do much of my own car maintenance and do some personal carpentry work out of my garage, and open and close the main (8 foot steel sectional) door several times a day. Haven't had a problem with my screw-drive opener since I installed it 4 years ago.
-Mike
May the forces of evil become confused on the way to your house.
#12 of 25 OFFLINE   Steve_Ch
Steve_Ch
  • 982 posts
Posted January 05 2002 - 07:46 PM
>>I can't speak for other brands, but the one I installed each opener comes with it's own code, and the opener "learns" the code for each remote and stores it by pressing a learn button on the opener then the button on the remote, rather than changing some dip switches on both. <<
I beleive (and certainly hope) that's how all the new ones work, surely makes more sense, and that's why I said "in the older days".
#13 of 25 Guest_Eric Kahn_*
Guest_Eric Kahn_*
Posted January 06 2002 - 09:11 AM
all of the new genie and chamberlain (sears) openers use code switching remotes now
you can even buy a new reciever with a code switching remote and retrofit most old units
#14 of 25 OFFLINE   Dave Smith
Dave Smith
  • 183 posts
Posted January 06 2002 - 10:17 AM
I got a screw-drive (actually two) when I moved in to my house last year.
Noise is not an issue, the drive itself is virtually silent, it's the doors themselves that cause the racket Posted Image And from 10 feet away you can't even hear those.
#15 of 25 OFFLINE   Dennis Reno
Dennis Reno
  • 865 posts
Posted January 07 2002 - 01:41 AM
Quick question - can the openers that use code changing remotes be operated by the programable door openers in todays automobiles? I'm not talking about the remote that comes with the door, but the units that are hard wired in new cars and trucks.
#16 of 25 OFFLINE   BrettB
BrettB
    Producer
  • 3,024 posts
Posted January 07 2002 - 02:39 AM
Have had a Genie screw drive for a little over a year now and have no complaints. Not sure if all the models do this, but mine opens about twice as fast as it closes. I guess they keep the closing speed slow for safety. Nice and quiet.
Like Dave said, it's the doors that make the noise. After about six months my door was noisy as hell. Bought some white lithium grease in a spray can with the little plastic straw (like WD-40) and sprayed every hinge and point of friction. Good as new. Also, use WD-40 on the monster spring every few months.
Has anyone noticed how the first time you use the opener after a power outage it moves in slow motion. By the second time it's back to normal. What causes that?
#17 of 25 OFFLINE   Kevin Eckhardt
Kevin Eckhardt
  • 185 posts
Posted January 07 2002 - 03:28 AM
Brett,
The model you are referring to is in the Genie Excelerator line. I have one of these as well. Home Depot was running a special on the Genies ($50 installation vs. $100) in December. The guy who installed it explained that the first time it opens after a power outage it goes slowly so it can calibrate itself for your garage door. Once it figures out when to start and stop the screw it opens at the normal "double speed". So far mine has worked well and I like the fact that it opens faster than other openers.
Kevin
AFI challenges:
Movies - Last seen: Raging Bull, 68 to go
Laughs - Last seen: It Happened One Night, 82 to go
Thrills - Last seen: Raging Bull, 67 to go
Passions - Last seen: The African Queen, 83 to go Heroes and Villains - Last seen: Max Cady - Cape Fear, 73 to go
#18 of 25 OFFLINE   John Tillman
John Tillman
  • 598 posts
Posted January 07 2002 - 03:50 AM
I've had a Home Depot Genie screw type for about six months and I like it. Nice and quiet as compared to different Sears models I've had (both chain & worm).
The Genie replaced a craftsman, which had a fried circuit board from a passing storm. I did a Johnny-5 disassemble, took it to my Sears parts supply house, where they chuckled & said "sorry, can't help". I smiled back and said, "Guess a need a genie to fix this".
__
JT
#19 of 25 OFFLINE   Philip Hamm
Philip Hamm
    Lead Actor
  • 6,885 posts
Posted January 02 2004 - 03:26 PM
OK, I'm in the market again, with a new house. I went to Lowe's recently and really was attracted to the belt drive openers. I know a good deal about drive mechanics and their individual wear and service needs from my many years of motorcycle maintenance. Chains and screws both need lubing. Belt drive is quieter and smoother than either, with virtually no maintenance requirements. Very attractive, but very expensive as well. I plan on owning this home for 30 years so I'm willing to spend what it takes to get something that will last.
Any new recommendations?
Philip Hamm
Moderator Emeritus
#20 of 25 OFFLINE   Shawn C
Shawn C
  • 1,434 posts
Posted January 02 2004 - 05:38 PM
I have a Martin garage door opener. I put it when when I got my new garage door. It's exceptionally quiet. It is a belt drive.
The opener fob is nice since it transmits at 40MHZ, whis is different then most other openers. The problem is that you have to get your openers from them, and HomeLink won't work without an adapter.
