Dan Driscoll
- Aug 1, 2000
I just got a used AVR 300 and it came with a CR-90 remote. The AVR works fine and sounds great, but I haven't been able to figure out how to select the DVD-Audio (aka EXT 7.1 or MCH) 7.1 analog input with the remote control. The previous owner never used the 7.1 inputs, so doesn't know how, either. The input itslef works fine, I have my Oppo BDP-83SE connected to that input and when I manually select it on the front panel it sounds fine. I just haven't been able to figure out how to do it with the CR-90 remote.
There is no dedicated button on the remote for that input and I've tried dozens of key combinations, to no avail. The manual isn't any help, it references the CR-80 remote. The CR-80 was replaced by the CR-90 in later shipments, but the manual was never updated. I did download the CR-90 manual, but still haven't been able to figure it out.
Any suggestions would be appreciated!
