Hi all,
I just joined the forum after stumbling across it while trying to find more info on Fluance and a receiver that will go well with it. So thanks to the many people who have posted on Fluance speaker topics.
I have an old Panasonic box theater setup from about 15 yrs ago in my main livingroom which is slowly being upgraded. I replaced the front speakers with Klipsch towers and the panasonic receiver with a Denon several years ago. Will upgrade the speakers and maybe the receiver next year most likely.
Right now my focus is on my new purchase which I'm waiting on shipment. I purchased the Fluance 5.0 XL Series with the Bi-polar surrounds. Btw, my first time with Bi-polar hope they are ok? I do not have a receiver for the system and not sure which to buy. I do not want to spend a crazy amount of money on a fancy receiver because this system is for my basement and not really my main focus. I checked on Amazon for discontinued or refurbished receivers but not sure which will pair well with this system.
Any help you guys can provide will be much appreciated. I do have one ask for the receiver. I want it to have audyssey or something similar for ease of setting up. My Denon has been amazing and running strong for 8 maybe 9 years now. So maybe another Denon but it's not a must.
Also, where would I be able to find some decently priced stands for the surrounds? Should I get stands or mount them? If mounting is better, how should I place them? I know I've a ton of questions but am trying to learn and research all of this as much as possible.
Vai
Vai
