iTylerA
I started this thread on another forum site and got almost no support. I currently have a Sony HTS-S380 HTiB system that I'm looking to upgrade from. I've considered both getting a HTiB like the Onkyo HT-S5600 or the Onkyo HT-S9400THX, and making my own system.
If I were to make my own system, my budget falls between $600-$800. So far I've chosen this setup:
Receiver: Denon AVR-E400Front L/R: Sony SS-F7000Surround L/R: Sony SS-B1000Center: Sony SS-CSBSubwoofer: Now this is one of the areas I'm having trouble with. Someone previously suggested the Dayton Audio SUB-1200, but I'm concerned about the frequency response not having a low enough bottom end. The front speakers on this setup get lower than the sub. I myself am considering the Sony SA-W2500 which is smaller than the Dayton with less power, but a better frequency range. I definitely need input on the sub choice. Also, both of these are front firing. Is it worth the time and effort for me to find something down firing? I'm concerned that a front firing sub mayy be too directional, but a down firing sub may not work acousticly since the room I have it in is wood/flooring with no carpeting. My total if I stick with the Denon receiver, Sony speakers and sub puts me around $700. If possible I'd like to keep it around that range, but I'm willing to flex up if necesarry seeing as my original budget was $300-$400 lol.
I'm pretty much set on the receiver since it has the features, power, and audio codecs I'm looking for. I'm open to any feedback and replacement of any of the components I've chosen thus far.
Also, I found this under the specs of my old HTiB system. It runs 3ohm speakers and this is the info it gave under THD. I can't tell if this is actuually bad or not so any info on this would be appreciated.
On a scale of 1-5, 5 being "Holy crap! how have you been listening to this garbage?!?", how bad is that?
With 3 ohm loads, both
channels driven, from 180 – 20,000 Hz; rated 84 watts per channel minimum RMS power, with no more than 1% total harmonic distortion from 250 milliwatts to rated output
