Denon AVR-3300 Volume Issue (1 Viewer)
regulator23
Russ
I have never had a problem with my unit before, but now the volume will not go very high. You can't hear anything until you get to about -5 or so, and then it doesn't get loud at all. I have reset the microprocessor, I have opened it up and checked the 4 visible fuses, and I have checked all of the settings on the unit. I thought I'd check here before I took it in for service. I really don't want to upgrade at this time as this unit has always performed awesome for me. Thank you for viewing and for your thoughts.
Phil A
Central FL
Phil
How is everything hooked up and what is hooked to the receiver (what source is being played)? If connected via the multi-channel analog input, you may wish to look at page 27 of the manual. Page 39 of the manual indicates: "The volume can be adjusted within the range of –60 to 0 to 18 dB,*in steps of 1 dB. However, when the channel level is set asdescribed on page 23 or pages 44 and 45, if the volume for anychannel is set at +1 dB or greater, the volume cannot be adjustedup to 18 dB. (In this case the maximum volume adjustment rangeis "18 dB — (Maximum value of channel level)" Page 45 has info on the fader function.
regulator23
Russ
Thank you. Right now I don't have anything hooked up. I am just trying to get it right using the FM radio tuner, but still having no luck. I'd like to be able to rule out an improper setting issue.
Phil A
Central FL
Phil
Russ - do you have a decent antenna and is it all the stations? How about another source? Does the same problem persist if you play a CD for example?
regulator23
Russ
I have an antenna hooked up and it is the same with any station. The problem started when everything was hooked up (CD player and a DVD player) and it was the same problem with either of those as well. Last night I did try the multi setting on and then off and it doesn't change anything. I have the manual and had also tried adjusting the individual channel levels, but that's not the issue either. I appreciate any thoughts and input you have. Thank you.
Phil A
Central FL
Phil
Other than trying the pages I noted above in the manual, I did not notice anything else. It the problem with a CD or DVD player the same whether it is hooked up to an analog and digital input on the receiver?
B1GMARC
Does your Denon have that "evening", "day" sound option? At first I wondered why my Denon sounded so low. Lo & behold it was one of my reasons it sound so low. Mine is the AVR 591.
acinstallation715
